radiator fluid
Old Mar 6, 2006 | 06:48 AM
dmfitz82's Avatar
Default radiator fluid
I only have 75K on the odometer, but my radiator is going out fast. I have a strong leak around the top metal seal all the way around.
I have already ordered an OEM replacement, but my question is: does anyone know the fluid capacity of the OEM radiator? Also, any preferences for fluid choice?
Thanks in advance!
Old Mar 6, 2006 | 06:52 AM
stitos2k's Avatar
Well, stick with Type II fluid first off. You might as well get the honda stuff, at least you'll get the right fluid.
No idea how much you really need to fill it, but you're going to need to bleed it anyway, so buy extra whatever it is. You don't want any air bubbles in the system.
Old Mar 6, 2006 | 07:03 AM
dmfitz82's Avatar
any tips on bleeding it??
Old Mar 6, 2006 | 07:18 AM
xviper's Avatar
https://www.s2ki.com/forums/showthread.php?s=&threadid=86811
Old Mar 6, 2006 | 07:23 AM
dmfitz82's Avatar
Thanks for the link!!!! I was looking in your DIY's earlier, but I couldn't find anything pertinent to the radiator.
Thanks.
Old Mar 6, 2006 | 03:05 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Here's a BIG tip.
Make sure you have good hot heat in the interior when your done bleeding. If you don't, you've got air and will overheat the car for sure. It can take up to 15 miles for it to start overheating with air in the system. I had to teach Honda this a long time ago, when the guy called me on the side of the road after Honda changed the engine. Pathetic.
Old Mar 8, 2006 | 07:52 AM
dmfitz82's Avatar
Thanks!!! I'm going to change it out tomorrow.
ookielookie
Feb 25, 2013 05:41 AM
ziggy[x]
Feb 17, 2010 08:38 AM
03s2kman
Jan 23, 2005 09:42 PM
knifegun
Nov 15, 2004 06:09 AM
