Radiator leak.
Old Aug 9, 2010 | 02:14 PM
s2k925's Avatar
Default Radiator leak.
So, My radiator is leaking on the top on the drivers side. As the engine runs the coolant slowly puddles up in the foam area directly in front of the radiator. Its not a hose from the top because it slowly puddles up from below, looks almost like a fast growing mold the way it puddles up.. Suggestions?
Old Aug 9, 2010 | 02:31 PM
gCHOW's Avatar
OEM radiator? sounds like the top plastic cover has cracked and you'll need a new radiator.
you can try one of the aftermarket all metal core radiators - koyo, mishimoto, etc.
Old Aug 10, 2010 | 05:13 AM
AusS2000's Avatar
Many radiator places can replace the top and bottom plastic tanks quite cheaply.
Old Aug 10, 2010 | 07:18 AM
Requiem's Avatar
Thats the same area where mine cracked. I just bought one off ebay for like $90. Works great.
Old Aug 10, 2010 | 09:46 AM
s2k925's Avatar
I ordered a Koyo yesterday.. $150 wasnt too bad, plus free shipping. I'd rather just replace it then try and repair only the plastic at the top.
Old Aug 10, 2010 | 10:21 AM
gCHOW's Avatar
nice. thats what i did.
there are a bunch of good DIYs on the radiator change. make sure you turn the heater on!
also, pack extra coolant in your trunk cuz your coolant levels will be low for a few days after the change while it readjusts and gets rids of all the air pockets.
Old Aug 10, 2010 | 02:05 PM
crank's Avatar
the tanks crack on oem s2000 rads, pretty common problem, pickone up at a junkyard or something !!
civdaddy
Apr 30, 2013 01:53 PM
kbmass
Jul 1, 2011 09:34 AM
cs2k04
Sep 12, 2009 12:20 PM
tmkpres
Oct 9, 2008 07:32 PM
JDMSAMAD
Jul 6, 2007 09:16 AM
