Radiator replacement
Old Nov 30, 2007 | 05:49 AM
Shannon's Avatar
Rommel - very nice, thanks so much. Nice setup there, makes me jealous I would've loved to have gotten the nice stuff, but couldn't do it due to funds. Got an aftermarket OEM equivalent - Koyorad for $160 (still has the plastic top). I do have a Comptech intake though, so you're right, there is plenty of room!
Old Dec 1, 2007 | 10:42 AM
ShMooveS2k's Avatar
dwnshift- are you still using OEM fans or you upgrading. do you even need to upgrade the fans or just preference?
Old Dec 2, 2007 | 10:30 AM
Shannon's Avatar
Did the job yesterday! Really easy
Old Dec 2, 2007 | 10:56 AM
PeanutButter's Avatar
Did you buy a new one yet?
Im selling one with fans.
Old Dec 2, 2007 | 12:35 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by dwnshft & xlr8,Nov 30 2007, 01:40 AM
I recommend replacing stock radiator clamps with these, for a better seal..
Man I really gotta disagree on that one....
The most expensive cars in the world use the spring style clamps found on the s2k.
Screw clamps loose tension over time and create leaks. I've seen it counless times in the business. OEM spring clamps never leak.
The most important tip is to make sure all the air is out of the cooling system. An S2000 can be driven up to 20 miles with air in the system, then suddenly overheat without warning.
Old Dec 2, 2007 | 01:04 PM
NVMY4N's Avatar
good info to know.
Old Dec 2, 2007 | 02:00 PM
Shannon's Avatar
Yeah, the only thing better about the screw clamps is that they are a little easier to work with, but the spring style seems to be better, I agree.
I let the car run for a while with the radiator cap off to 'burp' it. Some big bubbles came out after it was warmed up.
Old Dec 2, 2007 | 02:13 PM
zdave87's Avatar
Member
Happy S2KI Birthday Shannon
Old Dec 2, 2007 | 02:19 PM
Kyushin's Avatar
Banned
I know this is off topic, but what oil filter is that you have on, doesnt look like OEM, and RR said oem are pretty much da best. Just lookin out for ya ^^
Old Dec 2, 2007 | 04:22 PM
Shannon's Avatar
WHOA! You're right Dave!!!! Thanks!!! Wow - look as all those stars
