Random check engine like
Old Oct 10, 2018 | 01:26 PM
project2k4's Avatar
Default Random check engine light
Went to auotoze & they say it’s a cylinder 1 misfire &
suggest replacement of Variable Valve Timing solenoid for $700 parts & labor. Car drives perfecting fine vtec & all. Mind you this is a rebuilt title S with 150k+ miles. Was planning on selling it with a new job starting soon. I’m suspicious of shops to begin with. Could It’d be spark plug? Or coil pack? Car is worth
$5k max so I have a hard time spending roughly 1/5 its worh on this. Any suggestions?
Old Oct 10, 2018 | 01:47 PM
noodels's Avatar
A second opinion .
get s/hand one 30 dollars, 2 bolts, and for a plug in part..
Old Oct 10, 2018 | 01:52 PM
zeroptzero's Avatar
The fact they told you it is a variable valve timing solenoid tells me they know nothing, there is no such part by that name. If they mean the vtec solenoid valve that won't cause a misfire on one cylinder. It is almost always gong to be a fuel injector or coil pack, I would double check the spark plugs to make sure they aren't oil soaked. If you don't want to spend too much money reset it and drive it and see if it continues to crop up.
rmk232
Apr 3, 2015 10:10 AM
Thomas Guide
Apr 3, 2014 07:01 PM
mason.whitlow14
Feb 25, 2014 08:00 AM
leesfer
May 14, 2012 06:04 PM
CTMechE
Mar 6, 2008 04:49 PM
