Re-using the clutch pressure plate
Old May 22, 2012 | 08:58 AM
ack5252's Avatar
Default Re-using the clutch pressure plate
When replacing the clutch, would it be acceptable to re-use the pressure plate? What about the release bearing?
Old May 22, 2012 | 09:17 AM
zeroptzero's Avatar
I personally would never re-use the release bearing, the cost and effort involved to remove the tranny wouldn't be worth trying to save the release bearing if it failed later down the road. If you have 60k miles or more on your pressure plate I personally would swap in a new one, a mildly used low mileage pressure plate could be fine but I wouldn't re-use an older pp.
Old May 22, 2012 | 11:58 AM
cdelena's Avatar
Of course you can re-use any part that appears to be low wear, but since the clutch replacement expense on this car is mostly the time/labor most of use use new parts is we are in there.
Old May 22, 2012 | 12:19 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have re-used many pressure plates with 100% success. I found a way to spin them and resurface them.
Bearing I would never re-use.
Old May 31, 2012 | 09:04 AM
ack5252's Avatar
I appreciate the insight guys.
mikefifth
Nov 15, 2014 04:16 PM
Phatt
Aug 14, 2012 10:35 AM
tothemaxx
32
Apr 28, 2004 12:50 AM
desert tortoise
Mar 24, 2003 04:20 PM
