pressure plate/throwout bearing
Hi.
As some are aware i have been having issues with my clutch.
It has got to the point now where it is undrivable in stop start traffic.
I suspect throwout bearing or pressure plate.
Clutch was replaced for oem honda 1 year ago.
If the TO bearing or pressure plate are at fault is there any upgraded parts i could use here?
Also how much is this likely to cost? My clutch change cost 400 but i think they may charge more for this.
Systems are: hard notch at bottom of pedal travel that requires force to overcome. Slight stick at bottom of clutch causing slippage and kangarooing.
I had a new slave installed and this is the noise it produced: http://youtu.be/Mz23giz01pI
I refurbed my old slave which is non cdv and that is installed now. Doesnt produce that noise though.
You can also see the notch here: http://youtu.be/-VvMlknQeas
Please someone help!
Did you recently adjust the clutch rod ?
or maybe was another member on here
Not you then
AZ-S2000
06-03-2013 03:40 PM
desert tortoise
03-24-2003 04:20 PM
