rear brace screws sizes?
Old Mar 20, 2003 | 10:54 AM
north9586's Avatar
Default rear brace screws sizes?
I changed out the exhaust on the S and when I went to put the lower rear brace back on the screws that hold it there had walked off ! Does anyone know what the sizes are so I can go get replacements? Thanks!
~Andrew
Old Mar 20, 2003 | 05:46 PM
north9586's Avatar
bump
Old Mar 21, 2003 | 08:34 AM
Bassem's Avatar
i'm guessing you mean the lower cross brace...the same straight stamped sheet metal thing that mounts to the little emission control box behind the driver side?
as i recall the four bolts that hold it to the subchassis are either 12mm or 24mm head bolts (usually means 8mm or 10mm bolt diameter, take a 12mm socket to the home depot when you buy them). The other two that hold onto the emission box bracket are 10mm head bolts. They are no longer than 3/4" either (for all of them).
sorry its not precise, but its better than nothing. besides, these bolts are pretty cheap anyway, get a bunch of different sizes, and keep a little collection.
bassem
Old Mar 21, 2003 | 09:31 AM
north9586's Avatar
Thanks alot Bassem! I want to get it hooked back up!
~Andrew
Old Mar 21, 2003 | 11:53 AM
Bassem's Avatar
just reread my post....
i meant to say 12mm or 14mm head size bolts!!!! sorry about that.....
i just checked the maual, and they are specified as 10 x 1.25mm. no length given, but like I said, 3/4" is long enough. Bolt head sizes are usually 2 or 4mm larger (hence the 12 & 14mm reference above).
hope you reread this before buying anything!
bassem
Irish TuneR
Mar 22, 2014 12:49 AM
s2konroids
Jul 11, 2013 04:22 AM
James_JDM
May 30, 2013 04:35 AM
CHIPPO
Mar 15, 2010 04:39 AM
krazik
Nov 21, 2003 11:17 AM
