Rear Diff failure
Old Oct 12, 2005 | 01:13 PM
cdelena's Avatar
Default Rear Diff failure
The diff failed today, and it sounds like the pinion is stripped. Waiting for it to be towed to the dealership.
It failed with a downshift to second and a throttle application but the car was not being pushed at all. Do these things fracture, weaken, and then give up? I am not one to do launches or beat the gears hard so I really did not expect this.
I have a year left on my extended warranty so it will be towed to Honda and I will expect a repair, but have heard of refusals. Any tips on getting this covered?
Old Oct 12, 2005 | 01:25 PM
hoppy's Avatar
I don't see why they would refuse. You said you didn't drive your car hard, so it seems to me like the rear diff went out pre-maturely. When you down shifted did hit rev-limiter? or was it completely random?
I have a question about the rear diff while on the topic.
I launch my car all the time, and so far my rear diff is ok. I planed on upgrading it once I added some whp. Should I just go ahead and upgrade it now, because I do drive my car pretty hard sometimes. What are the current best options for rear diff upgrade?
Perfomance and price.
Old Oct 12, 2005 | 01:35 PM
Ludedude's Avatar
Administrator
Now might be a good time to swap out that avatar
Old Oct 12, 2005 | 01:41 PM
cdelena's Avatar
Nowhere near the rev limiter.. downshift and throttle at probably 3 - 4K.
I like the avatar and still maintain that smoothly doing laps should not be hard on the car, just brakes and tires.
Although the car is designed as a sports car and produced by a manufacturer with a rep for reliability, it seems to me that it is fragile in ways that many are not.
Old Oct 12, 2005 | 01:42 PM
XXX240's Avatar
My friend is going for a Skyline conversion...
If you are after some serious power, thats a good option.
Good luck
Old Oct 12, 2005 | 01:43 PM
CrazyPhuD's Avatar
I was thinking the same thing.....
Old Oct 12, 2005 | 01:48 PM
CrazyPhuD's Avatar
Good luck
All depends upon price...the mounting kits/axles aren't cheap but it can be done. I actually recently picked up a set of R33 axle's and an R33 diff with S13 cover, to do a swap. I still need to get a set of axles and the mounting brackets(which won't be cheap), but out of pocket costs are only sporting $160 so far. Should make the diff 'bulletproof' for drops and power...BUT it just puts the pressure on something else in the drive train to break.
Old Oct 12, 2005 | 01:52 PM
xviper's Avatar
Has your diff fluid maintenance been impeccable? That's about the only thing I can see them coming at you on. (Except maybe the track miles if they knew about it.)
Old Oct 12, 2005 | 02:11 PM
Slows2k's Avatar
Get your sevice records prepped, and don't get angry if they turn you down right away.
Stay persistent and call Honda's customer service # if you run into probs. Flying off the handle and shouting at the dealer doesn't help your case out. (if you run into probs)
Old Oct 12, 2005 | 02:13 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I can't tell you the amount of clutch dumps and drifting I do with my car. At 55k, so far so good. I have a backup incase, but I think it's the fluid that has been a factor. I've got LE607 in there.
What type of fluid/time on it/was in the dif?
LE is waiting for the first failure so they can warranty it
