Rear diff fluid
Old Mar 4, 2009 | 06:18 AM
offroad2000's Avatar
Default Rear diff fluid
I know this has been done to death. And yes I've read the saved forums on the subject. But I have a specific question on brand of oil. At work we use Pennzoil 80W90 GL-5, and we also have the synthetic version of that. It's 75W90 GL-5. Would this be good to use? Anybody with experience with Pennzoil or is most brands good as long as the weight and GL are correct? I don't race it. I mostly just drive it on the weekends. At least until it warms up some.
Old Mar 4, 2009 | 06:36 AM
r6elmo's Avatar
Should be fine, it's recommended that whatever you use is 75W90 and is or exceeds GL-5 standards.
make sure it has some sort of friction modifier that is intended to be used in LSD differentials - that's the important part. if it does NOT have that they I would not use it.
Old Mar 4, 2009 | 06:39 AM
The Gent's Avatar
I am also curious because when I took it to pennzoil for a diff oil change, they added Pennzoil Syntechtic 75W90 GL-5.
How does it compare to other oils?
Oil specs...
http://www.pzlqs.com/Tech/Pdsheet/Domestic...AE75W90GL-5.PDF
Old Mar 4, 2009 | 06:50 AM
PDS's Avatar
PDS
You're kidding right
There's no friction surfaces in our diff - it's a Torsen - unlike a traditional LSD
Absolutely no need for friction modifiers
Old Mar 4, 2009 | 06:57 AM
I was under the same impression about the friction modifiers. The Gent, have you had any problems so far? How long has it been since you had it changed?
Old Mar 4, 2009 | 08:57 AM
The Gent's Avatar
Only had it for about 1000 KMS and the car is now stored. From what I understand, this oil meets OEM specs and will cover my warranty (bought it with warranty -- that's why I had a shop do it)
s2000maniac
Dec 17, 2012 01:51 PM
dedonderosa
Sep 5, 2008 05:46 AM
dtmcnamara
Feb 28, 2008 05:15 PM
irev9k
Jan 20, 2008 01:26 PM
