Rear Sub Frame Replacement
Old Jun 9, 2017 | 04:42 PM
AZS2KDancer's Avatar
Default Rear Sub Frame Replacement
I was shown a small deflection in my passenger side rear subframe which may be contributing to an alignment issue when the car was in a lift recently for an unrelated issue.
That right side rear wheel is unable to get into alignment specs by just a little bit. I'm seeing some inside wear on that tire.
My thought process is that the subframe was damaged in an accident a few years ago when I kissed a guardrail, and not replaced at the time the bodywork was done. That may also have bent the upper control arm.
i have the service manual, and it indicates that there are only 6 bolts holding the subframe on. What else would need to come off in order for me to replace my subframe.
The subframe has Spoon sub-frame bolt collars. Will I need to replace the collars and the bolts with the replacement piece? Any special tools required?
Thanks in advance.
Old Jun 9, 2017 | 09:03 PM
B serious's Avatar
driveshaft. exhaust. cross brace. you'll need to disconnect the charcoal canister after removing the bracket. e-brake cables, brake lines, Etc etc.
Just take off whatever is in the way. I swapped mine (by myself) without glancing at a manual. No biggie.
Old Jun 10, 2017 | 03:55 AM
bgoetz's Avatar
yeah it isn't bad. Just be sure to disconnect everything with the charcoal canister
KUpton83
Mar 21, 2014 08:57 AM
bluemetals2k
Feb 21, 2012 04:59 PM
Golem
Jun 15, 2011 09:59 PM
mike_s2000
May 26, 2011 01:20 PM
biker1
Apr 11, 2006 10:32 AM
