Rear toe seized
Old Apr 26, 2012 | 07:02 PM
p0staboy's Avatar
Default Rear toe seized
Went to get my alignment done and the rear toe was sized so it couldn't be adjusted. Just wondering which arm to order from this diagram thanks
Old Apr 27, 2012 | 02:50 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
10,11 is the left and right toe arm.
You will also need the bolt that goes through it if they have to cut it out (looks like 25 or 26 can't read the number)
Old Apr 27, 2012 | 03:12 AM
jonmizu's Avatar
I had some wd-40 sprayed on it drive around for a day went back then they got it off
Old Apr 27, 2012 | 04:30 AM
miguel329's Avatar
yup i used pb blaster lubed few days went back, they got it didnt need to spend money on new parts
Old Apr 27, 2012 | 09:14 AM
speedjunky01's Avatar
if this worked on my old 91 CRX Si in new england its whole life, it will work on your s2000 haha
Old Apr 27, 2012 | 09:37 AM
stupkid's Avatar
Soak the seized bolt with brake fluid and leave it there for 10 minutes. Don't be afraid to put on a lot of brake fluid, then it becomes much easier to take off.
Sent from my iPhone using Tapatalk
Old Apr 27, 2012 | 02:03 PM
Tam4511's Avatar
For future reference, don't use WD-40. Its useless compared to brake cleaner or actual penetrant like pb blaster.
Old Apr 28, 2012 | 01:18 AM
SpitfireS's Avatar
If they are properly seized: you have to cut and order new parts.
That is what you get wen you drive this car in all kinds of weather.
Because you're not supposed to do this, according to Honda NL.
mas2kap1
Mar 18, 2014 05:36 PM
mike_s2000
May 26, 2011 01:20 PM
minh
Nov 3, 2006 11:54 PM
mikegarrison
Jan 8, 2005 02:50 PM
mfabry
Apr 1, 2003 08:02 AM
