DIY rear control arm replacement (anti-bumpsteer)
Old Dec 28, 2004 | 05:40 PM
mikegarrison's Avatar
Default DIY rear control arm replacement (anti-bumpsteer)
http://www.eskimo.com/~mikeg/S2000/bumpsteer/
Shows removal of OEM rear control arms and installation of Go-Fast Lab's anti-bumpsteer rear control arms.
Old Dec 28, 2004 | 05:44 PM
xviper's Avatar
Mike, this is good info. I'm adding this to the FAQs.
Old Dec 28, 2004 | 06:10 PM
Also working on SS brake lines and brake ducting. Expect to see those writeups when the work is finished.
Old Jan 8, 2005 | 07:25 AM
Gernby's Avatar
Former Sponsor
What is the purpose of the new control arm? Is it to "fix" the suspension geometry of a lowered car? If so, how do you know the optimum length?
Old Jan 8, 2005 | 07:29 AM
Gernby's Avatar
Former Sponsor
I just read about it in the Market Place, but it still isn't obvious how you determine the right length.
Old Jan 8, 2005 | 11:50 AM
Your alignment tech will set the length for you. Assuming you go to someone experienced enough. My car is not lowered, but I was going to higher rear camber. Even with the extra length extension, the alignment tech ran out of toe at 3 degrees camber. Apparently the lower arm became the main limiting factor.
Old Jan 8, 2005 | 01:00 PM
Gernby's Avatar
Former Sponsor
I guess I was WAY off. I thought you would want to SHORTEN the control arm to fix the geometry of lowering it. I also thought there would be some mathematical aproach to figure out how much to shorten it based on how much it was lowered. I don't know of any alighment shop that I would trust to "wing it".
Old Jan 8, 2005 | 02:50 PM
I shopped around for a place that is used to working on track cars and race cars. The local tire shop probably wouldn't be the best bet.
james0933
Aug 18, 2014 03:12 PM
farzam
Aug 5, 2011 02:24 PM
t0m
Oct 16, 2010 05:45 AM
