>>> rear window wrinkles
Old Jul 22, 2007 | 09:12 PM
amielo's Avatar
Default >>> rear window wrinkles
ok im probably sure theres another thread about this but i havent found it.
my rear window a 2001 and its making wrinkles or some sort of shape (i dontk now looks like a heart kinda shape)
how do i get ride of it? is there anything i need or could do to have it removed? i put meguiars plastx on it couple of days ago. mayb it was cause i put too much pressure on the outside part of the window.
info would be appreicated thank you
Old Jul 22, 2007 | 09:14 PM
silentdancer's Avatar
when ur top goes down make sure theres no creases while it folds into place
Old Jul 22, 2007 | 09:47 PM
s2kminator's Avatar
you cant dude, if your window is making a heart shape wrinkle that means she is falling inlove with you. To get rid of it you have to dump the car now.
Old Jul 22, 2007 | 09:57 PM
tekstar's Avatar
Pressure from applying plastx did not cause it. Follow what silentdancer has to say. Some people buy tubes from muz ( http://www.prestigeautoaccessories.com/sto...21416e585ce6898 ) to ensure that the plastic window folds down correctly.
If there are already creases in it that will not go away, as a last resort: get some boiling water and SLOWLY pour it over the plastic window. Make sure not to get any on your paint. This will cause your plastic window to curl, and in 10 minutes or so it will be flat and good as new. Again, be careful with this.
Hope this helps.
Old Jul 23, 2007 | 07:51 PM
amielo's Avatar
Hope this helps.
for the boiling water. would the top have to be half way or when the top is fully secured.
what would happen if the water goes too fast? does it have to be boiling or just HOT?
Old Jul 23, 2007 | 09:52 PM
tekstar's Avatar
when the top is fully secured. if you do it too fast, you risk getting it on your paint and that is not what we want.
https://www.s2ki.com/forums/index.php?showtopic=218111
TookayS2K
Mar 20, 2007 07:17 PM
BobsS2000
Sep 26, 2005 11:46 PM
cbb
Aug 5, 2002 04:55 PM
cabinfever
Oct 20, 2001 07:57 PM
