rebuild! HELP
Old Sep 21, 2008 | 09:09 PM
Mrblu's Avatar
Default rebuild! HELP
Just did a compression test on cylinder one after a engine light went on (p0301). Thought it was the spark plug or coil pack, but it wasn't. We tested and it was at 90, then it went down. The other 3 are fine, but the first one (cylinder 1) sucked like shit.
Brother is doing a cylinder leak test to see what the real problem is: the gasket, valves, or pistion. Hopefully just gasket or valves. This will be tomorrow.
I probably need to rebuild my top block motor, any recommendations on where in Sac/or any where to go for a good competitive price? Give me full cost of rebuild and labor, or just the rebuild.
Old Sep 21, 2008 | 09:29 PM
Stealth_SUX_'s Avatar
If piston wall ends up being scored it would be cheaper to buy a used block unfortunatly.
Old Sep 22, 2008 | 10:24 AM
N2oExpresS2k's Avatar
You can't go wrong with a bottom end from Honda if that's the problem. 2k for a new bottom end is very reasonable IMO
http://www.hondaautomotiveparts.com/auto/j...NSMISSION++ASSY.
select engine assy form the last drop down
There's usually some f20/f22's for sale in the classifieds as well.
Old Sep 22, 2008 | 11:15 AM
I tried that actually.. Majestic wont ship the whole bottom end.. You have to pick it up at there location..
Old Sep 22, 2008 | 11:18 AM
So go pick it up at your local parts dept. See if a rep their can get you a discount.
Old Sep 22, 2008 | 11:30 AM
yea tried that they wouldnt match majestic they meet half way, after me talking to several managers that is..... So you may or may not have good success with it.. I said screw it and bought a used motor off this forum..
I couldn't be happier with my decision..
But back on subject.. hopefully you wont have to go through that..
Find anything out yet about your motor?
Old Sep 22, 2008 | 11:53 AM
Mrblu's Avatar
you got it used instead? well i might consider that. Its my cylinder head that needs to be rebuild. I called a machine shop here and said that they can do it, but because the motor is sensative, and depend on how bad the condition is, it might not even pass smog. Talked to a smog guy and he said they only test for 3000 rpm so it should be fine.
Got a friend who is willing to sell me his ap1 head for my ap2 messed up head, or get the head rebuild and pay my uncle in law for labor.
Dont really know what to do.
Old Sep 22, 2008 | 11:55 AM
the head shouldn't be a big deal to rebuild.. Its the bottem block that is.. If its your head consider yourself lucky..
And if you get the head rebuilt by a good shop they shouldn't tell you that it might not pass smog.. thats bull..
Old Sep 22, 2008 | 12:08 PM
If they told you that then either find another shop or buy a used head. Used head would be a lot better IMO than having it rebuilt.
Old Sep 22, 2008 | 12:18 PM
Mrblu's Avatar
the smog guy said the same thing too. The machine shop said it because they rebuild a ap1 poorly mantained head and didnt go well after the rebuild.
