Remote Keyless Entry Question
I just bought a 2000 Sk2. Naturally, no owner's manual. I have two remotes for the keyless entry system with the option button. The Panic button is the only thing that works. Can't set the Alarm, or lock/unlock doors.
Any Ideas?
Dave
Any Ideas?
Dave
First, you need to find out if there is an alarm or is it just keyless entry. Stock cars come with keyless entry only, alarm is an option. Keyless entry is pretty simple so there could be only a few problems, according to owner's manual:
#1- One of the doors is not fully closed
#2- The key is in the ignition
#3- Weak battery
If there's an alarm in the car then it's going to be a bit more complicated to figure out the problem.
Good luck!
[QUOTE]Originally posted by davestern
[B]I just bought a 2000 Sk2.
#3- Weak battery
Good luck!
Originally posted by Johnny--2K
you should have an owners manual.....did you check the secret compartment?
[QUOTE]Originally posted by mas
[B]First, you need to find out if there is an alarm or is it just keyless entry. Stock cars come with keyless entry only, alarm is an option. Keyless entry is pretty simple so there could be only a few problems, according to owner's manual:
#3- Weak battery
#3- Weak battery
SECRET COMPARTMENT ? ? ? Are you talking about the storage box between the seats?
dave, there is another compartment that opens up or towards the back of the car. The one you are speaking of opens to the front of the car. Kind od likea "two-part" glove box.
Anway the "secret" compartment usually means the one that opens to the back.
