Removing busted bolt
Old Jun 23, 2007 | 04:04 PM
Kyushin's Avatar
Banned
Default Removing busted bolt
I noticed when i tried to take out my TCT for replacement, one of the bolts snapped and a small part of it is still sticking out, how would I go about removing this so I dont have to go through the headache of takin it to a shop?
Old Jun 23, 2007 | 04:30 PM
Kyushin's Avatar
Banned
After some google research, will this do the job
http://www.tools-plus.com/hanson-53403.htm...m_term=HAN53403
Old Jun 23, 2007 | 04:45 PM
jeggy's Avatar
yes, that is usually the weapon of choice.
hard part will be drilling the hole in the limited space.
Old Jun 23, 2007 | 04:50 PM
Kyushin's Avatar
Banned
i dont think drilling a hole will be possible, any other ways to get it out?
Old Jun 23, 2007 | 05:10 PM
chino101's Avatar
Check this thread out: https://www.s2ki.com/forums/index.ph...pic=473941&hl=
The OP of that thread broke a bolt in the same area, but for the VTEC solenoid.
The owner eventually soaked sprayed Liquid Wrench on onto the busted bolt, let it soak over night, then "use the pick and hammer and hit it counterclockwise" and got it loose. I guess the key is having patience, I hope the S is not your daily driver.
Old Jun 23, 2007 | 05:14 PM
IcebergS2000's Avatar
If enough of the bolt is sticking out, maybe you can get some vise grips on it and turn it out? Maybe if you need to you could use a dremel and make some flats on it.
Old Jun 23, 2007 | 05:30 PM
Kyushin's Avatar
Banned
Got a local friend commin by tomorrow to help with the situation, if lucky well get it out and the car will be running tomorrow... only time well tell. There is only a small bit of the thred sticking out, the bolt head completely snapped off.
vtaky0
May 3, 2014 11:27 AM
Sideways
Jun 11, 2010 09:51 AM
peters2000
Nov 30, 2009 10:14 AM
mxt_77
Jan 31, 2008 06:08 AM
LonS2k
Oct 4, 2005 08:08 PM
