missing bolt on top of airbox
Old May 3, 2014 | 04:06 AM
vtaky0's Avatar
Default missing bolt on top of airbox
just fitted a standard airbox to my AP1 this morning as the previous owner had a crappy induction kit fitted. however, im missing a bolt.
http://i200.photobucket.com/albums/a...psg9nyimp6.jpg
any idea what size it is or part number?
Old May 3, 2014 | 04:45 AM
mikefifth's Avatar
Any small bolt with washer should sort that Tim
Sorry I forgot to send that to you!
For a temp fix you could get away with a cable tie!
Mike
Old May 3, 2014 | 07:45 AM
zeroptzero's Avatar
pretty sure it's a 5mm bolt. Same thread and pitch as the bolt that you use to compress the TCT upon removal. 5 x 1 ? . You can pretty much choose any length you want as it sits in a deep well, 10-15mm would be plenty though.
Old May 3, 2014 | 11:27 AM
vtaky0's Avatar
Thanks guys, 5mm bolt did it.
Had a bit of an eventful afternoon fitting it Mike. One of the three brackets on the airbox has snapped off so had to make my own bracket. Also the screw that goes into the chassis wouldn't go in, suspect the thread is ruined. One of the cable holders had snapped off at the rear of the airbox too.
Boostaholic
Aug 18, 2021 06:49 PM
Sideways
Jun 11, 2010 09:51 AM
mxt_77
Jan 31, 2008 06:08 AM
kevsS2
May 4, 2004 11:53 PM
