removing front LCA
Old Apr 21, 2006 | 10:35 PM
suterusu's Avatar
Default removing front LCA
I'm replacing my front LCA, and I am having trouble getting the eccentric sleeve out of the rear bushing. I got the bolt all the way out of the sleeve, and the nut on the top is loose enough to bounce around, the whole assembly rotates, so its not siezed in there. Does anyone have a trick to getting it out, or am I gonna have to drop the subframe a bit to push it out from the top.
-Andrew
Old Apr 22, 2006 | 09:53 AM
Gvr4-330's Avatar
Maybe just give it a couple of taps. The way it works is the sleeve sits in the nut on the top, but they're just attached by friction. If you can pull at the bottom sleeve with a pair of channel-locks or just a couple small taps from the top should loosen it.
Rob
Old Apr 22, 2006 | 10:31 AM
suterusu's Avatar
I couldn't get to it from the top because the frame rail is close enough you can't even lift the bolt. I tried ViceGrips and I ended up spinning it so I could get a screw driver in and tap it out near the bottom of the bushing. Thanks though!
-Andrew
bgoetz
Mar 31, 2017 06:56 AM
SS Tony
Apr 30, 2016 01:34 PM
marcucci
Apr 17, 2010 05:43 AM
Paper Lawyer
May 4, 2007 07:32 AM
