Removing Hubs - HOW?
Hello everyone...
I am buying a used BBK and instead of me buying extended studs as well, we are trading hubs.
I don't know how to remove the entire hub from my car. Can anybody help?
Also, with a 7.5'' + 48mm offset LE37, what spacer will be needed to run a Stoptech BBK?
Originally Posted by WyattH,Dec 2 2005, 10:07 PM
Hello everyone...
lates
Unbolt the lower ball joint, and seperate the tie rod ends/upper ball joints. Backing the nuts off then striking with a large hammer workswell at seperating the tie rods and ball joints. Remove the ABS wheel speed sensor from the knuckle.
Swap entire knuckles/hubs.
SomethingWicked
Dec 27, 2004 04:44 PM
