Repacking the CV axles
Old Jan 7, 2014 | 01:12 AM
  #21
Seanix's Avatar
Originally Posted by S2KPUDDYDAD
What grease are you guys using for re packing the CV axles? And how much?
I'm looking to use Valvoline full synthetic grease approved for CV joints.
hey Puddy, i thought u were the subject matter expert on cv's and diff's
Old Jan 7, 2014 | 02:44 AM
  #22
S2KPUDDYDAD's Avatar
Not CV axles, that is why I thought best to ask those with experience. As to differential gear boxes, I know that very well
CV axles seem to be a pretty easy thing to do basic maintenance on
The axles are back together now and I will be installing them back into the car next week. I'm almost finished with the Version 2 PuddyMod rear cooling cover The first PM cooling cover had a larger heat sink than stock the V2 will have the large heat sink along with a larger oil capacity
Attached Thumbnails Repacking the CV axles-image.jpg   Repacking the CV axles-image.jpg   Repacking the CV axles-image.jpg
Old Jan 7, 2014 | 03:02 AM
  #23
freq's Avatar
^^^ Looking good w/ that fresh paint on there too.
Now you can add axle rebuilds to your resume.
Old Jan 7, 2014 | 03:41 AM
  #24
iamxpl's Avatar
im dreading having to do it on my car.
Old Jan 7, 2014 | 06:09 AM
  #25
darcyw's Avatar
thanks for the photos. looks easy enough if you've got them out anyway.
darcy
Old Jan 7, 2014 | 06:35 AM
  #26
darcy
Yes it is, just be sure to put the rollers back where you got each one from, that is why you see the blue and white dye. The tripod can only go on one way so you do not need to worry about inverting it by mistake.
Honda sells a rebuild kit as well if you find anything damaged, it has a new cup, boot, bands, tripod, rollers, and grease.
Old Jan 7, 2014 | 08:07 AM
  #27
s1mba's Avatar
Looks great. What did you use to paint them?
Old Jan 7, 2014 | 08:56 AM
  #28
Thank you, used DuplaColor low gloss black engine paint, dries quick and is very forgiving to novice spray painters
Old Jan 7, 2014 | 04:58 PM
  #29
freq's Avatar
The brass covers on the jaws of the vise, what are they called? I think I need them!!
Old Jan 7, 2014 | 06:22 PM
  #30
MM3Kwolik's Avatar
http://www.reedmfgco.com/index.html?..._vise_jaw_caps
