Replacement clutch problem
So i replaced my slipping clutch recently and for the 1st week or so it was great, then it started getting heavier and tighter if that makes sense. also right at the bottom it really get hard and then clicks really loud.
The strange thing is if i take the it half way past redline the clutch goes back to prefect for about 5 minutes then gradually starts clicking in the end, any ideas? Thanks
I got my mechanic to replace it and it was an exedy replacement , so im assuiming they did all the things you wrote, ive taken it back to him once and he said the air was leaking and he fixed that, but the problem came back so hes gonna have another look in 3 weeks, just dont want to wait that long
turns out its the pressure plate which i dont understand because it was brand new, hope its still under warranty....you think they did a s?"t job of putting the kit in or its just a crappy pressure plate?
Sounds about right, perhaps they didn't tighten it down evenly or maybe it was just a faulty part. Either way seems to me like they'll have to do it again for free. An expensine clutch kit like that should obviously last a lot longer than a couple of weeks! I took a risk buying and fitting a cheap clutch kit (if you can call £275 cheap!!) and so far so good. Let us know what the outcome is, although I suspect they wont tell you the full story if they are at fault!
JohnandKing.com
Sep 29, 2003 06:20 PM
