Replacement clutch problem
Old Mar 29, 2012 | 07:14 PM
mk84's Avatar
Default Replacement clutch problem
So i replaced my slipping clutch recently and for the 1st week or so it was great, then it started getting heavier and tighter if that makes sense. also right at the bottom it really get hard and then clicks really loud.
The strange thing is if i take the it half way past redline the clutch goes back to prefect for about 5 minutes then gradually starts clicking in the end, any ideas? Thanks
Old Mar 30, 2012 | 05:47 AM
paul2011s2000's Avatar
That doesn't sound good! I once fitted a cheap pull type clutch to a different type of car, and after a week the clutch release bearing failed and I had to do it all over again, was not happy! What clutch kit did you use? Did you grease the inside of the clutch release bearing? Did you grease the clutch release fork? Was the clutch release fork in good condition?
Old Apr 9, 2012 | 07:11 AM
mk84's Avatar
I got my mechanic to replace it and it was an exedy replacement , so im assuiming they did all the things you wrote, ive taken it back to him once and he said the air was leaking and he fixed that, but the problem came back so hes gonna have another look in 3 weeks, just dont want to wait that long
Old Apr 9, 2012 | 10:16 AM
I did my clutch a couple of weeks ago and checked/did the things I mentioned before, I've done a couple of hundred miles so far but all seems well. I think I've read somewhere on here about people having problems with Exedy clutch kits, even though they are not a cheap option. My local Euro Car Parts told me that Exedy make the clutch parts for Honda, but not sure if that's true. He said that air was leaking? I can't think what that is, unless he means he had to bleed the air from your clutch system. Keep us posted on how you get on, good luck.
Old Apr 18, 2012 | 09:40 PM
mk84's Avatar
turns out its the pressure plate which i dont understand because it was brand new, hope its still under warranty....you think they did a s?"t job of putting the kit in or its just a crappy pressure plate?
Old Apr 19, 2012 | 02:36 AM
Sounds about right, perhaps they didn't tighten it down evenly or maybe it was just a faulty part. Either way seems to me like they'll have to do it again for free. An expensine clutch kit like that should obviously last a lot longer than a couple of weeks! I took a risk buying and fitting a cheap clutch kit (if you can call £275 cheap!!) and so far so good. Let us know what the outcome is, although I suspect they wont tell you the full story if they are at fault!
oooBernard
Apr 17, 2013 11:59 PM
tehsu
Jan 4, 2011 12:42 AM
Gh0ztt
Feb 18, 2008 06:43 PM
JohnandKing.com
Sep 29, 2003 06:20 PM
