resistor size?
Remove the controller as well, if you wreck the car with the controller installed the impact sensors inside will trip, and the unit will be a paper weight.
Remove the SRS bulb from the cluster if you don't want to see it after that.
I don't want to give out the resistance #, as then people could build a airbag simulator for wrecked cars. instead of fixing them the correct way.
