resistor size?
Old Jul 31, 2005 | 11:08 PM
owenxguo's Avatar
Default resistor size?
what size of resistor do I need to remove the pass side airbag?
I did some research, the miata is 3 ohm, 1/4W, what about our S?
thx
Old Aug 2, 2005 | 05:01 PM
owenxguo's Avatar
no 1 help?
Old Aug 2, 2005 | 08:09 PM
Slows2k's Avatar
Why do you need the bag's resistance?
Old Aug 3, 2005 | 09:06 PM
owenxguo's Avatar
I am gonna remove the airbag, building a track car.....
Old Aug 3, 2005 | 09:13 PM
Slows2k's Avatar
Remove the controller as well, if you wreck the car with the controller installed the impact sensors inside will trip, and the unit will be a paper weight.
Remove the SRS bulb from the cluster if you don't want to see it after that.
I don't want to give out the resistance #, as then people could build a airbag simulator for wrecked cars. instead of fixing them the correct way.
Old Aug 3, 2005 | 11:45 PM
RACER's Avatar
Like you said, all you have to do is to remove the bulb.
J_STATUS
May 26, 2008 07:51 AM
S2Kyle01
Mar 4, 2007 07:51 PM
shadykit
Feb 19, 2006 12:02 PM
owenxguo
Jul 19, 2005 02:08 PM
aznhomie
Feb 18, 2004 07:21 PM
