Right corner light doesn't light with keyless
I noticed last night that my passenger side front turn signal doesn't blink when i use the keyless entry but does work when using the turn signal. This might be a dumb question but any thoughts?
u have two different bulbs there in the corners.
the lower corner bulb are just parking lights. those are the ones that will flash when you lock or unlock. the upper bulb is your turn signal. ur turn signal bulb does not flash when you lock or unlock
looks like you have a blown bulb on the bottom.
mrpandahead
Aug 8, 2018 03:22 PM
alphalanos
Mar 15, 2013 03:48 PM
