Rough Running
Have a 2003 S2000 with K&N cold induction. Car is running rough sometimes. The rough running comes and goes away. Very confused what is wrong with it. It runs very good then all of a sudden it's start to buck. The engine light is on for a P0411. This shouldn't cause engine misfire. Confused!
Do some searching on the code.
P0411 Secondary Air Injection System Incorrect Flow Detected
You could have a vacuum leak which can cause the engine to run rough.
Also, check out this thread. https://www.s2ki.com/s2000/topic/350254-cel-p0411/
