Rough shifting into second
Old Feb 5, 2007 | 09:22 AM
tommyo's Avatar
[QUOTE]Has this always happened or just recently?
I bought it used in spring. This is the first cold weather I have experienced with it. I never noticed this till winter. If I am really careful I can reduce the crunchiness on the 1-2 shift.
Old Feb 5, 2007 | 11:05 AM
chino101's Avatar
I hear it more of a crunch rather than a grind. I've done a search on this subject as temps dropped to near and below freezing. Many other have experienced this with a cold transmission, and thus deemed it "normal". Others mentioned changing fluid to help remedy this annoyance.
I will try double clutching on the up shift to see if this helps, but still plan on doing the transmission oil change.
Since the transmission will be warmed up to operating temperature by the time you get to the dealer, they won't experience this problem.
The suggestions that I found from the serach was generally take it easy on all the shifts. It requires very little force to change gears. On the 3-4 change I can use one finger and pull it down into 4th, even on a cold 27deg.F transmission.
Old Feb 5, 2007 | 11:49 AM
iDomN8U's Avatar
I'm thinking that this is attributed to the increase of synco cones on 2nd.
I tried Honda MTF and it didn't change a thing, only have 23K on it, i'm thinking I will try the *NEW* honda mtf and if that doesn't cure it then GMSFM/Amsoil.
every other gear is smooth as silk
Old Feb 5, 2007 | 02:29 PM
s98d7fs's Avatar
Definitely the new fluid is a noticable improvement over the old formula at colder temps.
Old Feb 5, 2007 | 05:58 PM
brimstone's Avatar
iDomN8U: You need to wait a few hundred miles after the transmission oil change to feel the effects of the new oil. Another member told me recently that this is attributed to the porous texture of the carbon-fiber synchros, not sure how that applies to AP1s.
Old Feb 5, 2007 | 06:07 PM
importroadster's Avatar
I just switched my trans fluid over to Synchromesh , and wow! so much better shifting!
Old Feb 6, 2007 | 05:13 AM
jasonjm's Avatar
I always grinded in 2nd.
But Bill hooked me up and now it's more of a notch.
Did fluid change in Tranny(new Honda)
Fluid change in Diff(607).
Clutch fluid exhange.
Clutch pedal adjustment.
You still have to take it easy shifting though.
Old Feb 6, 2007 | 05:14 AM
jasonjm's Avatar
There is also a TSB on 2nd, 3rd syncro's for 04+
Old Feb 6, 2007 | 05:27 AM
iDomN8U's Avatar
Was it the Clutch pedal Adjustment that help fix the grind?
(I always felt that the clutch should be a touch more depressed/more release then what the factory has it at)
Old Feb 6, 2007 | 05:41 AM
jasonjm's Avatar
Factory settings are
My car felt the way you describe since day 1.
After the pedal adjustment, it's a completely different clutch feel.
Like day and night.
