Running rough after valve adjustment
I had a similar problem, when I did my first valve adjust. It had multiple misfire codes, which turned out to be a lose connecter on ignition coils 2 and 4. Once I plugged them in, all was fine.
I wouldn't consider a misfire in this car simple since there are multiple components that can cause it. What can be causing it? Bad connection (which was the case for me), bad ignition coil(s), broken wires, spark plugs etc.
Always use terminal grease when reconnecting any electrical connectors as well as apply some to the coil boots that go over the spark plugs. My guess is you have a bad connection with one of your coil packs. Disconnect everything, grease it all up, reconnect it and report back. That should solve your issues if the vehicle was fine beforehand.
Your all geniuses!!!
the connection between one of my coils was bad just greased em up and made sure they were seated And WA-LA, prrrs like a kitten. Thumbs up to y'all thanks again.
Another happy S owner satisfied again
the connection between one of my coils was bad just greased em up and made sure they were seated And WA-LA, prrrs like a kitten. Thumbs up to y'all thanks again. Another happy S owner satisfied again
Saad_Z
Jun 22, 2013 09:47 AM
