Rusty seat pan
Old Jul 17, 2015 | 03:10 PM
solitarycheese's Avatar
Default Rusty seat pan
I'm taking my seats apart to repack the bolsters and noticed some pretty bad looking rust. I poked at it with a screw driver and some flaked off but the metal seemed solid.
I have some Rust Cap around, think I should give it a spray?
https://i.imgur.com/pOhODMZ.jpg
Old Jul 17, 2015 | 03:50 PM
ktwenty's Avatar
I took my seat pans out and used rust remover then painted them
Old Jul 18, 2015 | 06:11 AM
slalom44's Avatar
Top Answer: 1
Clean them up before you paint them. Besides allowing the paint to adhere better it will remove any salt that might be on there.
Be sure to use a primer before painting it. You want to get good paint adhesion. Your interior appears to be getting a little more moisture than usual.
I realize that it looks bad but this is mostly surface rust. Seat frames are not considered to be exposed to the elements so are typically not heavily protected from corrosion. This is not just the case on the S2000 - all manufacturers do it this way.
StatixNWH
Jan 12, 2010 04:56 PM
LegendaryHarry
Mar 2, 2008 07:57 PM
campbuds
Feb 7, 2006 01:41 PM
fisting dwarves
Aug 4, 2005 04:15 AM
ITRbroham
Aug 28, 2002 10:39 PM
