Looking for new Seat
Old Mar 1, 2008 | 02:32 PM
LegendaryHarry's Avatar
Default Looking for new Seat
after my first day of track i was sliding a bit in my seat.
one probably cause the leather is sorta slick and two because im a pretty small guy.
so i was looking into a few choices of aftermarket seats.
1. Recaro SRD (if i can locate one)
2. Corbeau TRS looks like SRDs
3. F1 Spec Reclinable.
im basically looking for a seat i can get around 300-400. that wont block the glove box or do any rubbing and its reclinable so i can still effectively use the stock seat belt.
any suggestions either from my list or not?
thanks
Old Mar 1, 2008 | 07:47 PM
sspicollo8's Avatar
you'll be able to use your factory seat belt with a fixed back seat as well. i've got a recaro SPA and it's extremely comfortable as a daily driver. the only bad part about it is that the leg bolsters are really tall and it makes getting in and out a bit of a pain, but getting the regular SPG solves that problem. i even swapped my stock seat in for a long trip yesterday thinking it would be a little more comfortable, only to regret it the whole time. fixed back seats are generally cheaper than reclinables, so you should be able to get a better quality one with your budget too.
Old Mar 2, 2008 | 01:09 AM
but wouldnt the lap belt be too high and thus not securing me down
Old Mar 2, 2008 | 10:31 AM
sspicollo8's Avatar
I guess there's a possibility that it would with some seats, but mine has relatively high sides and the belt still sits against me all the way across. It's also pretty easy to unbolt the seat belt and feed it through the left belt hole in the seat so that it holds you even better, but I didn't feel that I needed to.
Old Mar 2, 2008 | 10:51 AM
Berner9's Avatar
How about a seat belt lock?
http://www.modifry.com/products/sbl/index.htm
Theres also another one out there that is $40 or so and its manual but it just locks the top shoulder strap.
Old Mar 2, 2008 | 10:57 AM
mavm86's Avatar
You need one of these: www.cg-lock.com
I had a harness in my previous car, and hardly notice the difference between the harness and the CGlock in terms of how it holds me in the seat.
Old Mar 2, 2008 | 07:57 PM
im leaning towards the f1 spec reclinable. does anybody know if its safe for HPDE's>?
JasonMG
Mar 25, 2019 06:15 AM
Suzuka_BlueS2K
Sep 13, 2013 03:40 AM
stlvtec
Feb 8, 2008 01:23 PM
tim62
Nov 9, 2004 09:52 PM
TJS2K
Aug 29, 2003 06:57 PM
