s2000 Ballast
Old Jan 6, 2010 | 05:18 PM
nguystep's Avatar
Default s2000 Ballast
I'm in need of a new ballast and I was wondering if there is anyway to check in person if the used OEM ballast your purchasing is in working condition.
Thanks in advance
Old Jan 7, 2010 | 12:45 AM
B serious's Avatar
Go to the junk yard. Snip off a plug from a civic/integra reverse switch. You need the female side.
It plugs into the ballast. Connect the ballast to a headlight make sure the grounding straps are connected also. It's best to do this with a headlight housing.
Ballast wiring:
White is positive. Black is negative.
Connect it to a battery. Ground first. Then power. MAKE SURE YOU DON'T HAVE THE POLARITY REVERSED OR YOU WILL BLOW THE BALLAST. I have done this. You do not want this.
FYI, I have a working AP1 ballast for sale. Have pics. LMK.
Old Jan 7, 2010 | 04:13 PM
Crisgo's Avatar
Good info Macgyver
Old Sep 11, 2010 | 11:52 AM
bbs2k_21's Avatar
Any pics of this reverse switch from the civic/integra..?
What is meant by "reverse switch".. Can anyone give more insight on this...
Onest
Apr 17, 2016 12:27 PM
AlexS2k01
Mar 3, 2016 09:32 PM
PaulG1968
Apr 17, 2014 10:54 AM
elksman
Sep 17, 2012 09:55 AM
Jed_Clamplett
Jan 3, 2011 06:19 AM
