S2000 noise inside cabin
Trying to find out where this is sound is coming from and why. I can only hear it from inside and sound comes from the middle/passenger side. Only makes sound when I'm at any speed even when in neutral
https://drive.google.com/file/d/1D_7...iSxW3agvv/view
Do you get the same noise with the roof down?
Thanks!
It has a hardtop on, the video doesnt do it justice but it sounds like its coming from the drive shaft or transmission. When I go into 4,5,6th gear it gets a little louder. All my gears are fine no grind or pops.
Just regular maintenance engine at the moment. I think the noise is either coming from the driveshaft or transmission. When I poke my head outside I cant hear it.
You can additional sound proofing under the carpet and in the doors.
https://www.s2ki.com/forums/s2000-ta...sults-1085903/
https://drive.google.com/file/d/1HHw...ew?usp=sharing
I listened to the video and I cannot make much of it at all. Have you ever checked the differential fluid or replaced it? You might try that.
Before I did my sound deadening I do seem to recall hearing the transmission gear whine much more than I do now. That is why I did not do any sound proofing forward of the crossmember as I wanted to be able to hear the engine!
