S2000 stock Vtec eng/disag point ?
Im pretty sure its 5900 to engage and 6200 disengage on decel. I think, dont quote me on that. You should definitely hear a difference when it kicks in and the tach shows 6k so its around there obviously if you dont hear a difference above 6k you might have a problem
My MY00 engages at 6,000 RPM and disengages a little below that. The disengagement point has to be lower than the engagement point. I don't have an exact number, but disengagement is at at 5,800-5,900 RPM. It's just low enough so that you don't drop out of VTEC on the 1-2 shift.
Originally Posted by RED MX5,May 11 2007, 05:58 PM
BTW, Modirfy has a free mod that produces an indication whenever VTEC is engaged.
it's been done since...well, since the first vtec motor rolled out from the factory
Originally Posted by iam7head,May 11 2007, 09:15 PM
or your can just tap the power from the vtec solenoid and hook it up with beeper/light/underbody neon tube
Originally Posted by RED MX5,May 11 2007, 07:15 PM
Yea, but Modifry's mod uses an existing instrument cluster light.
on my other car, the previous owner drilled and mount abunch of bs light and switches and alarm thing in the dash. (like 5-6)
