S2000 Ticking Noise - Spun Rod Bearings?
I think checking oil levels should be a sticky!!!!!!!!
Lots of people don't check their oil. Period.
Cmon mods, make it happen.
Edit: I forgot it's in the s2000 common problems sticky. But maybe it's own sticky would be a good idea.
Start saving for a new motor now, if your lucky you will be able to get another 10-20k miles out of it. Your current oil consumption at roughly 3Q in 1000 miles is banging on deaths door. The lower your oil gets the faster it will burn, so your only best option right now is to top it off as its needed when its needed, which sounds like a couple times during a tank of gas.
Poor oil level and oil quality will cause any TCT to act up just fyi. They work under oil pressure, and if that drops from the mentioned, they won’t work.
You may also have a problem with the belt tentioner pulley, these do go out eventually. With 160k miles it’s highly possible.
Sorry for the bad news/situation. If it makes you feel any better ive been through 5 motors in my S career.
**Please check your oil religiously guys, its 90% of the premature downward spiraling early death of these engines out there, im convinced. The rest are with us Boosted guys.
5motors? Damn! Mind me asking how they've come and gone?
Everyone has been so helpful; I'm so happy to be part of the s2000 community.
Originally Posted by arsenal' timestamp='1412869808' post='23362876
Please report back, mine is making the same sound
does it sound almost like a fluttering clicking when accelerating?
Originally Posted by GorgeousAP1' timestamp='1412887221' post='23363388
[quote name='arsenal' timestamp='1412869808' post='23362876']
[/quote]
All he did was press it against the engine and touch the belt some which started to change the pitch and speed of the clicks until it went away
Nothing fancy
francor10
Jun 23, 2012 10:48 PM
