S2000 Turbo
Old Jun 15, 2001 | 01:10 PM
  #31
Justin's Avatar
derryck , What kind of fuel management system did you get if any? Also, where did you get the turbo manifold from?
Justin
Old Jun 15, 2001 | 01:16 PM
  #32
derryck's Avatar
My mechanic chose an FMU with a secondary set of injectors and uses the V-AFC for some additional tuning. My mechanic is making the manifold.
Old Jun 15, 2001 | 02:12 PM
  #33
S2R's Avatar
S2R
derryck,
You mentioned needing a 3" exhaust. Are you talking about the piping or the tip or both? Also, if you have a Mugen or HKS exhaust already, do you still need a new exhaust if you get a turbo?
Old Jun 16, 2001 | 03:27 AM
  #34
johnny's Avatar
Originally posted by KIDS2000
I believe there is a Japanese Co. called "Zero-1000" that makes a turbo kit for s2000. From the hong kong tuning magazine i have here it says its good for some 400+hp. Should be sweet but it's still a pretty unchartered terittory for most of us...
Yeah, that company, I believe, is better known as Top Fuel.
Old Jun 16, 2001 | 10:00 PM
  #35
S2K Fan's Avatar
Those pics are beautiful
Old Jun 17, 2001 | 05:08 PM
  #36
ultimate lurker's Avatar
Derryck brings up an interesting point. He said $8,000 to do it right. Comptech has not "done it right". No engine management changes, obvious systemic problems (cracking brackets, drivability issues, etc.). Were you to do a Comptech system right (engine management, intercooler, etc.) then you could expect to pay closer to $7k-$8k retail.
There are some reasonable price ranges for components listed in this thread. If you wanted to do a Comptech style turbo system using a boost dependent regulator and check valves, you could easily pull it off for $5k or less. Just don't expect me to buy one :-)
UL
Old Jun 18, 2001 | 04:53 AM
  #37
derryck's Avatar
S2R,
The 3" that I was referring to is the piping, none of the aftermarket exhausts for the S2000 that I know of are currently 3" diameter piping. You could use an aftermarket exhaust but there would be some restriction in the exhaust flow.
Old Jun 18, 2001 | 11:05 AM
  #38
S2R's Avatar
S2R
I guess holding off on an aftermarket exhaust would be good if you're going FI later on.
Old Jun 18, 2001 | 11:16 AM
  #39
Tanqueray's Avatar
[QUOTE]Originally posted by ultimate lurker
[B]Derryck brings up an interesting point.
Old Jun 18, 2001 | 12:17 PM
  #40
derryck's Avatar
FYI, we have decided to go with a smaller exhaust housing as to hit full boost by 3500-4000 RPM's. The smaller exhaust housing coupled with the ceramic ball bearing turbo should make for a pretty quick spool up. As soon as we get a closer to being finished I will probably post to determine interest in a turbo kit for the S2000. I've already discussed it extensively with my mechanic and if there's enough interest, then we'll move forward.
