s2000 washer fluid tank
Hello,
i have one question for fluid tank.
My current is leaking at around half full.
I managed to find only this used one which is on the pictures.
Is this on the picture good for ap1 with headlamp washer?
shouldn't it have 2 outlets?
Thank you
Thank you
That's it, but it should have a neck portion. Is yours leaking from the reservoir or the neck? See the following link.
2000-2003 HONDA S2000 AP1 WINDSHIELD WASHER FLUID RESERVOIR OEM FACTORY
thank you,
i don't know where it leaks. i only know that it leaks around half full.
for the neck i hope that it doesn't leak. i didn't take it out. around croatia i only found this used bottle without neck.
