s2000 wont start
Old Jun 20, 2013 | 05:08 PM
crank's Avatar
Default s2000 wont start
any ideas ? does the clutch safety switch have a fuse ?
Old Jun 20, 2013 | 05:10 PM
crank's Avatar
can i jump the start switch conector somehow to see if its just the switch ?
Old Jun 20, 2013 | 06:02 PM
Murphg05's Avatar
so, you push the start button and it doesn't do anything? No cranking, clicking? Have you checked the switch on the clutch pedal?
Old Jun 20, 2013 | 07:14 PM
XxMerlinxX's Avatar
Can you push start it?
Old Jun 20, 2013 | 09:26 PM
crank's Avatar
ya car does nothing everything works etc, earlier it did this while i was getting gas so i just hoped it would work and it started right up...got home and now it wont do anything. i jumped the clutch bypass switch, swapped the two under dash relays, checked all fuses under the dash. the starter is an oem honda unit and has less then 50k miles on it. the start switch lights up. I'm almost certain it would start if i push started it when my friends are around i will confirm tomorrow. is there a chance the actual switch could be bad ? i took it out and cleaned it but still nothing.
Old Jun 20, 2013 | 09:28 PM
crank's Avatar
battery is fine alternator is fine everything is good. except it wont start lol...im stumped.
Old Jun 20, 2013 | 09:53 PM
Murphg05's Avatar
check the wires on the starter. i've heard some members on here say they thought the wires were on good, but found them loose or even off all together.
Old Jun 21, 2013 | 03:57 AM
crank's Avatar
ya ill do this sometime today.
crank's Avatar
anyone else have some ideas for me ? i really need to figure this out
Old Jun 21, 2013 | 05:13 AM
crank's Avatar
car started this morning, when i got to school i shut it off and tried to start it again, wouldn't start.
