s2000 wont start
Old Jun 26, 2013 | 05:39 AM
  #21
crank's Avatar
Originally Posted by Andersonracing
Originally Posted by crank' timestamp='1371820399' post='22622484
car started this morning, when i got to school i shut it off and tried to start it again, wouldn't start.
does it crank at all? Can you hear the starter solenoid actuating? Check the little signal wire on the starter, it is a spade connector and sometimes they can get pulled off, the wire loom is really tight there.
gona check it out
Old Jun 26, 2013 | 05:40 AM
  #22
crank's Avatar
Originally Posted by yetanotherbrian
Originally Posted by XxMerlinxX' timestamp='1371784470' post='22621899
Can you push start it?
Is it even possible to push start an S2000? If it is, then same question if the battery is dead!
With fuel injection and a dead battery, the pump won't be pressurized.
i just jump started mine in reverse this morn : )
Old Jun 26, 2013 | 06:29 AM
  #23
jl56tc's Avatar
Im telling tou the starter solinoid is bad
Old Jun 26, 2013 | 09:08 PM
  #24
crank's Avatar
im gona pull the starter sometime soon just so busy with school. the starter is oem honda and has less then 50k miles on it. seems odd to go bad so soon. checked all wires goin to starter every single relay and fuse clutch start switch etc. no idea what it is. I'm more of a mechanical type gear head then electrical things.. anyhow im familiar with bad starters and although i know how elusive they can be for some reason i feel like it is somthn else. i swapped start switch buttons with a freinds s2000 as well as batteries and still the same issue. so ive eliminated those aspects
Old Jun 26, 2013 | 09:15 PM
  #25
crank's Avatar
i was just on majestic honda and saw 2 prices for a starter ones was 193 and the other was like 400 ?? i bought one from there last time and it was deff not that expensive.
Old Jun 27, 2013 | 06:38 AM
  #26
jl56tc's Avatar
just go to advance auto and buy a new one ... its not that bad there I think... should be a couple hundred though... but def not 400
Old Jun 27, 2013 | 07:01 PM
  #27
crank's Avatar
i duno i use to work at advanced and the parts there are cheap garbage
Old Jun 27, 2013 | 10:10 PM
  #28
jl56tc's Avatar
well that was just an example......... but like a Delco starter should be alright...just saying
Old Jun 28, 2013 | 07:52 AM
  #29
crank's Avatar
any of you guys think the oem alarm could cause any of these issues ?
Old Feb 20, 2014 | 03:59 PM
  #30
rinz_LER's Avatar
Got something weird for you guys, had the same issue with my car where now its not starting (new starter less than six months old) BUT it starts if its in gear ONLY! Then after it starts then its normal until i turn it off and let it sit again.......
Isnt that weird though, only starting if its in gear, I usually start with no clutch (bypass the interlock switch) and in nuetral, but now it can only start if its in gear
Im hoping its just some wiring crap on the starter
