s2k grounding kit
So I was reading some articles and I've read that changing your ground wires etc can grant you more power. I was just wondering if anyone out there as acutally done this, and if it really does make a difference? also what kit did you use
lmk, thanks
david
lmk, thanks
david
Honda motors are already grounded pretty well it may make it so the lights dont dim/flicker when you turn on the stereo or accessories, but it will not net you much if anything in the power department
Search really is your friend. It has been bashed to death ad infinitum.
In summary, if you have a bad earth, fix it. If you don't, a bunch of wires strewn around the car will not make any difference so matter what brand name is printed on them.
Originally Posted by Slows2k,May 23 2007, 06:10 PM
Grounding kits are the Miracle milage carburetors from 20 years ago. And just as effective.
Grounding kit = JUNK
does it work in our car? no, i tried two different set and it's all rubbish.
just for the record, it didn't do a jack in term or power, accerlration, electric current, noise in my radio, mileage and all it did was lighten my wallet.
the first one was free consider i made those with left over thick gauge amp wire from the previous amp installation. the second kit was less than 10 dollar brand new
You have proven the only way a grounding kit does anything. English roadsters are not well known for having anything in the electrical system reliable and trouble free. You know why the english drink warm beer? Lucas built the refrigerators.
Only cars with insufficient grounds will benefit, because the car already has a problem.
The claims made my grounding kit manufacturers, parts whores and the JDM foolish are not based in electrical fact.
I'm all for a good healthy electrical system, but that doesn't warrant spending big bucks on a bunch of wire with a brand name on it. If you find your earth lead is defective or inadequate (and that's no surprise on an old british sports car) replace it with good copper wire. Having 'Fork' or 'Mugging' on it doesn't make it conduct any better.
it was funny watching the manager running around and not knowing what caused it. we know it's a electrical related issue but we can't find it once the car been "cool down" or sitting for a while. no one wants to dig inside the bay(it was a ground neat the manifold, if i remember it right) while the car was hot and running, by the time it's back to workable temperature the wires change back the orginal state.
