Screeching noise
Old Sep 12, 2008 | 05:42 PM
Spec_Ops2087's Avatar
Default Screeching noise
Well for the past few days I've been having a fairly loud screeching noise. When I clutch in, it remains and it only does it while cruising. If I accelerate/brake/turn it goes away. Also after about 15-20min it will go away so that ruled out a hub bearing. I've narrowed it down to the driver rear wheel.
I went out tonight to get some gas at a gas station about 3 miles away. It was raining so all the rotors had rust on them. Naturally after a couple of brakes the rust will go away. Will here is what I found once I got back in my garage.
Driver rear wheel rotor:
Passenger rear wheel rotor:
It appears I either have something under my brake pad / uneven wear in my brake pad / uneven worn rotor? Would this cause a screeching noise? Is it safe to drive?
I'm replacing the rear rotors + pads soon anyway but just wanted to make sure that this is most likely the problem.
Thanks
Old Sep 12, 2008 | 08:12 PM
Slows2k's Avatar
You bother to check to see if the pads are worn out?
Old Sep 13, 2008 | 03:40 AM
There was about 1/4" left on the pad
Old Sep 13, 2008 | 07:58 AM
DanTheManUK's Avatar
I had this, if there standard pads the wear indicator is f**king huge, it was the last thing I thought it would be too but it sure as hell as was.
Change the pads, fixed.
Old Sep 13, 2008 | 11:25 AM
I'll be changing them within a week or two, hopefully its just that!
klapamos
Jan 17, 2017 02:31 PM
zeroedout
Nov 30, 2012 02:46 AM
yupyup
Sep 27, 2010 12:54 PM
boosted_ap1
Apr 18, 2008 05:58 AM
student_driver
Jan 10, 2008 05:23 AM
