Secondary O2 Sensor
Old Jun 27, 2010 | 05:21 AM
AusS2000's Avatar
Default Secondary O2 Sensor
I'm running the AEM ECU so the Secondary O2 sensor is redundant. Can anyone tell me the specs on the diameter and thread bolt I'd use to replace it were I to remove it?
Old Jun 27, 2010 | 01:01 PM
SOHCmyDOHC's Avatar
I'm assuming this should be the same. got info from amazon.com
O2 Sensor Ring, Weld-on, Mild Steel, 18mm x 1.50 Pitch
Also, if you just happen to be buying anything from summitracing
http://www.summitracing.com/search/?keywor...or%20plug&dds=1
Old Jun 27, 2010 | 02:07 PM
s2k dre's Avatar
Everybody sells the plugs for it.
Old Jun 27, 2010 | 04:21 PM
AusS2000's Avatar
Thank SOHC, exactly the specs I need.
Dre, umm, thanks for your input too but there isn't an Everybody store around here.
Old Jun 27, 2010 | 04:24 PM
s2k dre's Avatar
i forgot that ur in sydney
Old Jun 27, 2010 | 05:13 PM
Slows2k's Avatar
A rear diff drain plug from a CRV or the s2k trans fill plug is the same size.
Old Jun 27, 2010 | 05:19 PM
AusS2000's Avatar
Ahh nice thank you. I have a spare rear diff that doesn't currently require it's drain plug.
Old Jun 27, 2010 | 05:24 PM
Slows2k's Avatar
Don't think the S2k diff plug is the same, worth a try though.
Old Jun 27, 2010 | 05:49 PM
AusS2000's Avatar
Gotya. I have a spare tranny too.
wazpe
Jun 20, 2022 01:36 PM
TerminatioN
Mar 2, 2011 08:01 AM
vadhert
Apr 26, 2009 09:13 AM
