Sensor / Gauge compatibility question...
Old Mar 5, 2004 | 05:02 AM
gropos's Avatar
Default Sensor / Gauge compatibility question...
Hi, All.
Please forgive my possible ignorance here, but I have a question about the compatibility between sensors and a particular vendor's gauges.
E.g. If I want to use a Defi gauge (or Defi "Display"), do I absolutely have to use whatever sensor(s) they recommend, or is there some sort of standard for this kind of thing, in which case I can use any sensor(s).
Old Mar 5, 2004 | 07:30 AM
modifry's Avatar
Honorary Member
I would bet you have to use their sensors.
Old Mar 5, 2004 | 07:36 AM
xviper's Avatar
My money's with Modifry. My take on this is the Defi is a fully electronic integrated system. The sensors have a specific type of harness plug that connects up with the control module. It is this control module that tells the gauge "readout" what to display. Oh, and the gauges have a specific harness plug too.
Old Mar 5, 2004 | 12:57 PM
johninator's Avatar
I would recommend using the same sensors specified for each gauge. It will be too much trouble trying to figure out calibration points for each sensors involved. Also, if you are using defi gauges, they are designed to be easy to install where each sensor plug and control modules have predefined modular plugs. I tried looking for the plugs myself, but I could not find a match. Either hardwire the sensor wires or just go with the defi sensors to keep things simple.
my defi setup
Old Mar 5, 2004 | 06:07 PM
gropos's Avatar
on a separate but somewhat related note.... does anyone know why there is no defi AFR gauge?
...Andrew
Old Mar 5, 2004 | 10:53 PM
johninator's Avatar
...Andrew
They do make one on the Defi D-gage series, but its only a narrow band gauge/sensor. If you are going to use it for tuning, you need a wideband sensor/gauge. AEM, PLX and others makes the wideband units.
jdmdohcpower
Dec 4, 2012 09:21 PM
superchrgds2k
Mar 6, 2010 08:55 AM
ian_6301
Car Talk - Non S2000
May 11, 2008 11:20 AM
vspc2nr
Sep 16, 2007 08:14 PM
03spa
Apr 19, 2005 03:09 PM
