Serious issues - Need help!
Old Jul 23, 2008 | 08:17 PM
  #21
kial007's Avatar
Were you able to check fuel pressure? My Honda service manual says that if you get the random misfire code with the accompanying individual cylinder codes (regardless of which cylinder or how many), to check fuel pressure.
Old Jul 23, 2008 | 09:01 PM
  #22
CKit's Avatar
Knock sensor? They're easily damaged when dropping the tranny and a fracture in the "microphone" could lead to fuel cut....
Old Jul 23, 2008 | 09:18 PM
  #23
Eyal s2k's Avatar
Interesting. How easily damaged when doing a clutch job? How likely would this be my problem. Would it cause a lopey idle as well?
Old Jul 24, 2008 | 09:01 AM
  #24
Togobox's Avatar
so how many probs do you have with the car? idle surge? misfire? etc..etc..
a bad knock sensor will not cause misfire or logpey idle. when eng. detected knock , it will retard the timing.also it will throw a cel.
Lopey idle could be the cause of intake leak, IAC valve stuck. bent throttle plate etc...
Dan H
Mar 21, 2012 05:39 PM
JLEEzAP2
May 1, 2011 12:28 PM
S2KballinOut
Feb 17, 2009 11:19 AM
ShMooveS2k
Jun 4, 2006 07:14 AM
