Seriously Stupid question
Old Feb 1, 2007 | 11:07 PM
blackout's Avatar
Default Seriously Stupid question
I have broken suspension front and rear on one side and that side sits like 1 inch off the ground. How would i go about jacking it up without use of a lift?
Old Feb 1, 2007 | 11:11 PM
Ustemuf's Avatar
can you get a jack under the differential from behind?
Old Feb 1, 2007 | 11:48 PM
tekka01's Avatar
im guessing not since the suspension on the front is broken
low profile jack would be my best bet
Old Feb 2, 2007 | 01:23 AM
jzz30's Avatar
jack up the rear subframe on the side that isnt low. then both sides should lift. then use another jack or put blocks under the wheel of the lower side and jack up the rear side of the low side and if you jack it up enough the front will also lift up.
if the car drives then just lay down a bunch of 2X4 in the shape of steps and drive up them.
Old Feb 2, 2007 | 01:52 AM
dbzerk's Avatar
rpg51
Nov 17, 2016 02:41 PM
StrokerSi
Apr 18, 2014 09:08 PM
spartikus1975
Nov 29, 2009 07:29 PM
mah00si
Apr 24, 2008 09:06 AM
Dembo
Jan 28, 2006 06:01 AM
