Seriously Stupid question
jack up the rear subframe on the side that isnt low. then both sides should lift. then use another jack or put blocks under the wheel of the lower side and jack up the rear side of the low side and if you jack it up enough the front will also lift up.
if the car drives then just lay down a bunch of 2X4 in the shape of steps and drive up them.
