Serpentine belt installed - Indicator line still the same as before
Old Aug 25, 2013 | 02:52 PM
Cali2K's Avatar
Default Serpentine belt installed - Indicator line still the same as before
2005 Honda S2000 115K miles
So I installed a new Bando 6PK1470 serpinentine belt today, install was pretty simple. Uninstalled the airbox, push down the tenionsor bolt, uninstall and install new belt. The problem is after the install the belt indicator line is the same as before. Did I use the wrong belt?
Pictures I found online but sililar to what mines look like.
Before install
What it should look like after install
After Install for my S2000
Old Aug 25, 2013 | 04:02 PM
speakeasy2009's Avatar
mine did the same thing, not as bad but it isn't were its supposed to be. Put maybe 5000 miles on it so far.
Old Aug 25, 2013 | 04:17 PM
meccjoo's Avatar
Maybe the belt tensioner is worn?
Old Aug 25, 2013 | 06:16 PM
Cali2K's Avatar
Could there be a possibility of the belt being install the wrong way? I have the belt with the letters facing towards the front bumper, so you can read it if I was standing in front of the bumper.
Old Aug 25, 2013 | 08:33 PM
realblag's Avatar
It is fine. That indicator actually shows stretch. If the new belt was manufactured 1mm longer than the OEM belt when it was new, it would show on that indicator. If the tensioner is still putting enough pressure on the belt, the length doesn't really matter. Vehicles were made for years with no "wear indicators". It was good to replace it for preventative maintanence, but don't over think it.
Old Aug 26, 2013 | 04:04 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Yes that little bit does not matter.
Only the oem belt will put it to the new line, but even that wont last long.
Old Aug 26, 2013 | 05:18 AM
Themikewoo's Avatar
This is good to know.
What condition was your belt prior to removal? How many miles did it have on it?
Old Aug 26, 2013 | 06:16 AM
Cali2K's Avatar
Thanks for the reply guys I will close my hood now and drive to work
The belt was actually still in good condition with 115K miles on it.
vtec4life57
Jun 15, 2010 12:39 PM
DDuds2k
Feb 2, 2006 09:15 PM
