serpentine belt, spark plugs replacement
Hello,
I was wondering if the belt needs to be replaced as part of preventive maintenance or it is supposed to be lifetime. I noticed that the belt color was bit rusted, when I opened the hood, not sure if it needs a replacement.
I don't know why we need to replace spark plugs on the s2k, there is no issue so far, and car has about 60k miles. I am concerned if by replacing the existing spark plugs, it may cause any new issues ?
Thanks.
Thanks.
Hello,
Thanks.
Thanks.
Your manual will suggest changing spark plugs every 100k or 7 years, and to inspect the serp belt every 30k for fraying and stretching. The belt shouldn't have any spider cracks or fraying edges, and the belt tensioner indicator will be out of spec if the belt has stretched too much. You can search to get more info on the tensioner and how to determine what is in and out of spec. This may help http://dave.harris.uno/s2000-replaci...uxiliary-belt/
I use oem spark plugs, and a goodyear gatorback serp belt.
