Settings for GCs/Koni's
Old Aug 1, 2005 | 11:34 AM
doorman's Avatar
Default Settings for GCs/Koni's
I recently purchised some Koni's and Ground controls from another member. I was going to put them on this past weekend but the height adjustment seemed a little off. With the Ground Controls sitting on the lower perch, I had to raise the part the spring sits on amlost to the top of the sleeve just to get the spring to touch the top.
Is this normal?
Where do most of you with this setup have them set?
I also noticed this pic.
I dont have the adjustment tool or the additional black rings are these needed.
Thanks
Old Aug 1, 2005 | 01:12 PM
Hockey's Avatar
PM Vtecvoodoo. Ryan is THE authority on this one.
Old Aug 1, 2005 | 01:15 PM
doorman's Avatar
That was my first step. Just have not heard from him yet.
Old Aug 2, 2005 | 09:23 AM
doorman's Avatar
Nobody Knows?
Old Aug 2, 2005 | 02:20 PM
vtecvoodoo's Avatar
I just set all four at the exact same height, set the car on the ground and measure from there. It`s pretty easy if you do this on a lift, as you can adjust w/out pulling the wheels off. It`s just a trial and error type of thing. Crank it up or down a few turns, drop and measure (repeat)
Old Aug 8, 2005 | 09:44 AM
doorman's Avatar
To the top with new question.
Old Aug 9, 2005 | 09:00 AM
doorman's Avatar
found out what the black parts were. still need adjustment suggestions.
Old Aug 10, 2005 | 01:03 PM
doorman's Avatar
According to Eibach and GC it is normal to have space between the spring and top when not weighted. That seems odd.
Old Aug 10, 2005 | 01:14 PM
jasonw's Avatar
Doesn't seem odd to me. The springs are shorter than normal and the sleeves don't expand/contract...
Old Aug 10, 2005 | 01:19 PM
vtecvoodoo's Avatar
Very normal.
calvinnnnn
May 28, 2017 06:42 PM
RichwiththeS2000
May 2, 2014 11:34 AM
chillout18
Apr 14, 2008 07:56 AM
pikkashoe
Jun 20, 2006 01:30 PM
doorman
Aug 9, 2005 10:30 AM
