Shaking in the rear
Old Jul 27, 2010 | 02:39 PM
sayaingokou311's Avatar
Default Shaking in the rear
So up until recently I started noticing when I start to accelerate in my car I get a shaking in the back of my car closer to the rear passenger tire. It only happens when I start to gas it a little bit. Does anyone have a clue? Please let me know. Thanks in advance.
Old Jul 27, 2010 | 09:25 PM
any ideas anyone??
Old Jul 27, 2010 | 09:32 PM
s2000maniac's Avatar
check your axle..torque it to 220 lbs if you havent already done so. Also check your wheel bearing.... and lastly make sure the lug nuts are tight..good luck
Old Jul 28, 2010 | 09:24 AM
vtec4life57's Avatar
How much are u lowered....
Old Jul 28, 2010 | 06:52 PM
about an inch, i checked out some information and i believe that my cv joints are bad due to a recall that was made by honda back in 2002. So ill check it out thanks everyone.
Old Jul 29, 2010 | 08:35 AM
BuckyN8's Avatar
I am having this same problem after lowering an inch. Figured it was the axle though.
Old Jul 29, 2010 | 08:49 AM
AP1rulz's Avatar
I did the CV cup swap and found NO pitting inside any of them, swapped them anyway, test drove it and still shaked; I retorqued the axles and retorqued the rear subframe bolts (two were not as tight as the others)... and VOILA, no more shakyness! Good luck
Rear subframe bolts are (2)19mm and (4)17mm
Old Jul 29, 2010 | 09:51 AM
fs2k's Avatar
check the rear differential mount,,,,
Old Jul 29, 2010 | 11:53 PM
y0itzCARL's Avatar
Get driveshaft Spacers! It might do you some good, If you already retorqued everything, I got the same problem, but unfortunately my axle shaft snapped. But just got a new one and also ordered some megan racing driveshaft spacers. If what I said did not solve the problem, You might have a bad U-Joint. Or you might just need a new driveshaft. but I hope you know that when you lower your car, you put stress on your axle/ball joints and thats why your getting that vibration/shakieness when you accelerate and such. I had to learn it the hard way haha. But yeah let me know on the outcome, if you solved the problem thanks.
shwinkwhite
Nov 9, 2021 07:01 AM
S2KNovice
Sep 12, 2016 05:49 AM
ATL_S2K
Sep 18, 2009 09:28 AM
urbanglowcam
Aug 15, 2009 01:31 PM
saaboteur
May 1, 2007 12:43 PM
