shaky idle
Old Sep 8, 2011 | 08:56 AM
speakeasy2009's Avatar
Default shaky idle
Hi guys.. I have a small issue with my idle when coming to stop or taking the car out of gear to come to a stop. I notice the idle drops and the car shakes, then it pics up and idles OK. I changed the plugs, PCV valve and my car has an after-market intake on it. No CEL at this time. Other threads say something about resetting the ECU or replacing the map sensor but I’m not a mechanic so I’m not sure I can do those on my own. Any thoughts??
Ricky
Old Sep 8, 2011 | 09:53 AM
mmm...vtec's Avatar
Have u tried cleaning the throttle body?
Old Sep 8, 2011 | 09:58 AM
s2000maniac's Avatar
Yea I have the same issues, but mine only happens when I come to stop from 30MPH and down. But if I come to a stop from a higher speed then it doesn't happen.
Old Sep 8, 2011 | 10:10 AM
no... any posts with pics on how to do this??
Old Sep 8, 2011 | 10:11 AM
mmm...vtec's Avatar
Ive seen a couple DIY of this on the foums.
Old Sep 13, 2011 | 03:09 PM
bankman64's Avatar
I had the same problem and it turned out to be a failed or faulty gas cap! See if you notice a stronger than normal fuel smell around cap. Mine finally coded an evap problem which led me to get a new cap and it solved idle problem instantly.
Old Sep 14, 2011 | 07:51 AM
Weasel497's Avatar
I have this problem too, but only with the AC on. If I blip the throttle a bit, like backing out of a parking spot, when i let off, it idles down and shakes pretty bad. But with the AC off, it's fine.
Old Sep 14, 2011 | 09:39 AM
yeah mine does that with the AC off. Ill check the gas cap but cannot find any DIY on cleaning the throttle body...
Old Sep 14, 2011 | 10:31 AM
JohnsS2000's Avatar
mine dose this and always has
Old Sep 14, 2011 | 04:39 PM
S2_4SHOOR's Avatar
Mine does this too but I wouldn't think it's a big deal though. It happens on other cars too but I believe our s2000 is just more noisyER and vibrates more.
